PS2 connect to PC monitor
Discussion in 'Playstation Forums' started by tosh, Mar 18, 2002.
  1. tosh
    tosh
    How can I connect my PS2 to my PC?
    Is there such a thing as a SCART card?
    I don't want to buy a full blown TV card. (TV licence issues)
    Thanks...
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Pop over to www.lik-sang.com
    They do a great PS2 VGA adapter that will let you connect your PS2 and your PC to one monitor. No idea about connecting a PS2 to a PC (and why you would want to?), but they do connection things for memory cards so that you can transfer saved games over the internet.
  3. tosh
    tosh
    Thanks for the info
  4. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    No probs m8.
  5. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    I remember seeing (a few years ago) a PCI card into which you could connect a PSX.
    Whether it would work for a PS2 I don't know. Nor do I know where you would get one!!
    Not a lot of help really!:(
    They definitely exist though! I am sure I saw it in a 'Computer Shopper' magazine advert...
  6. museumsteve
    museumsteve
    Jan 28, 2001
    7,981
    4
    Nth Hampshire
    +1,094
    as long as you don;t want VGA quality because the PS2 VGA box makes up the signal as PS2 doesn't have VGA support, just beware before you order..
  7. sean24
    sean24
    Hi Guys,
    Great idea using a PC monitor with your PS2. However before i go out and buy one of those adapters, could anyone let me know how i'd receive audio as most PC monitors do not come with speakers...
    Thanks,
    (hope i dont sound too think :))
    Sean
  8. ucci
    ucci
    Apr 19, 2005
    363
    Nottingham
    +4
    Some vga boxes allow you to plug in either phono leads or a typical headphone socket (like the one on the back of your pc) - you can then either plug in pc speakers or connect the box to an amplifier.
  9. ronnieboy
    ronnieboy
    Feb 15, 2006
    357
    +20
    I use 1 of these very versatile as it has pass through for pc so no need to swap leads
    Four display modes - PC, TV, AV & S-Video
    2 Video inputs (AV & S-Video)
    Resolutions supported
    640 x 480 @ 60Hz
    640 x 480 @ 75Hz
    800 x 600 @ 60Hz
    800 x 600 @ 75Hz
    1024 x 768 @ 60Hz
    1024 x 768 @ 75Hz
    1280 x 1024 @ 60Hz
    1280 x 1024 @ 75Hz
    TV Tuner - Pal I & B/G
    Picture in Picture display - Watch TV while working on your PC
    Remote Control
    £50 from this site and others
    http://www.gameseek.co.uk/pd/Multi0a79xafnnq6bfyu/PS2-PS1-Xbox-Cube-PC-Logic-3-Super-VGA-Box-with-TV-Tuner
  10. marcoh
    marcoh
    hello every1! :lease: :lease: help!! as my desk is limited to space i want to use my pc moniter for my ps2 (i don't have enough room on my desk for a extra tv screen)
  11. Hotshot147
    Hotshot147
    Feb 22, 2005
    96
    +4
  12. Jess cabre
    Jess cabre
    i don't get how to connect my PS2 to my PC
    i don't have money to buy anything
  13. dekoded
    dekoded
    Oct 30, 2004
    893
    Blackpool
    +45
    I've been using one of these for a few years!:
    http://www.internetvideomag.com/ProductReviews/products2002/XGA-TheaterReview.htm
    Not sure about price and availability now in the uk but I'm sure you'll find something.
    I don't actually use it for watching TV, just playing my ps2 on my computer monitor/speakers, it works really well for this and the pass-through pc signal is very good quality, you wouldn't even know you had it connected between your pc and monitor!
    It does tend to exaggerate the 'jaggies' in ps2 games, but only because of the low resolution of the games and the fact that the ps2 was really designed to be viewed on a normal TV which helps 'soften' the image due to a standard TV's low res. The colour is also less vibrant, but in general it's still a great bit of kit, the only limitation is the low res graphics from the ps2.
