PS2 Component RGB problems
Discussion in 'Playstation Forums' started by andycharger, Sep 6, 2005.
  1. andycharger
    andycharger
    Aug 11, 2005
    5
    Ive tried to connect my PS2 to my Hitachi 42PD 4200 Plasma TV via the RGB component lead I bought for the PS2 yet the picture is rolling constantly at the side of the screen. Its all distorted too.
    Could it be possible that my TV cannot work in this way with MY PS2? Does anyone know if there are some special settings I need to change?
    I have gone into the PS2 and changed the settings to RGB and component but still no joy!
    It works great through Composite but the picture is not good enough quality for my liking.
    Any pointers would be appreciated!
  2. Lionheart
    Lionheart
    Hi Andy...RGB and component are two different systems...do you mean you are trying to connect via the sony RGB scart system which would connect to an RGB enabled scart input on the tv or the sony component system which would connect to the tv via 3 leads ?
