PS2 Component problem.
Discussion in 'Playstation Forums' started by Bren, May 6, 2007.
  1. Bren
    Bren
    Jan 23, 2004
    1,688
    48
    +67
    I just got a component cable for my Ps2 & i can get a picture but no sound at all.Its not my amp as my Wii works fine using the same component switch box. Is there a setting i need to change? I am having to use composite at the moment which is not ideal.
  2. chrissyman
    chrissyman
    May 1, 2006
    418
    28
    +33
    can you not use the optical digital out on the ps2 to your amp?
  3. Bren
    Bren
    Jan 23, 2004
    1,688
    48
    +67
    All my optical ports are already taken
  4. Jonesey
    Jonesey
    Dec 10, 2004
    343
    28
    London
    +29
    have you changed the output settings also within the set up options?
  5. sk8
    sk8
    Sep 19, 2006
    556
    B&NES
    +17
    component doesn't carry sound
  6. PlexShaw
    PlexShaw
    Oct 12, 2005
    2,818
    London
    +546
    All the PS2 component cables I've come across have stereo (red and white) phono cables attached alongside the red/green/blue video cables.
  7. Bren
    Bren
    Jan 23, 2004
    1,688
    48
    +67
    Yep mine have that but no sound at all.
  8. PlexShaw
    PlexShaw
    Oct 12, 2005
    2,818
    London
    +546
    Faultly cable?
  9. Futurespect
    Futurespect
    Jan 10, 2007
    29
    Somerset
    Someone recently pointed this out to me.
    As for the sound, isn't there an option to disable optical out in the settings? I think if it's enabled then stereo is automatically disabled. Can anyone remember where that option is? If you just switch the PS2 on without a disc in, you'll want to look through the settings which come up.
