PS2 - Component or SCART?
Discussion in 'Playstation Forums' started by ginger, Nov 17, 2004.
  1. ginger
    ginger
    Just bought an LCD TV and looking for the best way to hook up my PS2 to it. Had originally assumed that the best I could do was to buy a Sony component cable (ca. £15) then I saw that IXOS make a SCART cable for £23 - known good make of cables. Does anyone know which of these is likely to be better? Is there a good third party manufacturer of PS2 component cables?
  2. CAS FAN
    CAS FAN
    Nov 24, 2003
    34,772
    167
    The Wheldon Road end!
    +7,938
    Generally the component cables are slightly better than the RGB scart, although RGB still gives a good picture. I'd go for component though. The official PS2 component cable is supposed to be pretty decent.
  3. ginger
    ginger
    Thanks - just found out that IXOS do make a PS2 component cable and it's available at hifistore.co.uk - will go for that
  4. MattTheBeanster
    MattTheBeanster
    Oct 23, 2003
    1,392
    Cornwall
    +93
    I've got one. Really good picture with the added bonus of prog scan that i find makes thinks much better too. Last game i played with that was Beyond Good and Evil. :)
  5. rich tee
    rich tee
    May 30, 2003
    412
    Bristol
    +7
    Save your cash old chum.
    If you have a Toys R Us near you they sell PS2 component cables for £7.99.
    I bought them and they are superb on my 32'' 100htz Tosh.
    They also sell cheap games and not just dodgy old ones.
    Richtee.
  6. rafaqat
    rafaqat
    Sep 28, 2004
    82
    I've bought the component cable from Game for Ps2 and I'm having trouble getting a picture on the plama (Panny Pwd6). Tried setting the plasma to accept component and RGB. Get bugger all with either setting. Have set Ps2 to output component signal too. Any ideas?
    It's connected directly to my plasma at the moment. Still no pic. :confused:
  7. rich tee
    rich tee
    May 30, 2003
    412
    Bristol
    +7
    Whatever Tv you have, plasma, Lcd, 100htz crt, if you're using component input / output with a PS2, both settings on the console and Tv should be the same.
    The console setting should be cr/yb/bc or something that looks like that, and the same for the TV.
    You can't have that setting and RGB because the plasma won't know where to send the pics.
    Also component is for picture only, it doesn't carry audio signals.
    If you are sure both settings are the same then scan through the AV channels on the Tv until you find the picture.
    Hope that helps.
  8. MillionDollar
    MillionDollar
    Nov 13, 2004
    55
    All the cables above, do they work with the new slim PS2?
  9. rich tee
    rich tee
    May 30, 2003
    412
    Bristol
    +7
    Of course, but does your TV support component? Only newer ones normally do.
  10. Kippers
    Kippers
    I have the same problem - got PS2 component into my amp, then component to vga cable to panny PWD6 with no picture....
    WHY OH WHY ..... somebody help /...
  11. daveb975
    daveb975
    Oct 25, 2002
    3,942
    103
    London
    +269
    I have got two cables for my PS2 - Ixos SCART and Sony component.
    I am stuck with using SCART at the moment as I have DVD on the component input of my plasma, and Xbox on VGA.
    I have tried them both out, though, and the component output is noticeably better - better colours and less jagged edges.
    I don't know if the Ixos component lead would be better still.
