PS2 component lead help?
Discussion in 'Playstation Forums' started by john<|>nhoj, Apr 23, 2005.
  1. john<|>nhoj
    john<|>nhoj
    Hello,
    After some help...
    I have just ordered a PS2 component + L/R audio lead from here...
    http://www.play-asia.com/paOS-13-71...0-1b4-43-3.html
    Just arrived. Plugged it into my new small PS2 (with GT4 disc in it...) and plugged the lead into my new screenplay 4805. I selected the component input. Screen blank!
    Have I done something wrong?
    Does the new little PS2 support component out?
    Does this lead work with the new little PS2?
    Does GT4 not work with this lead?
    Projector works on composite with both my xbox and my ps2...
    The Xbox Component lead (the proper MS one will arrive in a couple of days)
    So should then know if it is my ps2/lead or my projects RGB input...
    Help appreciated...
  2. Steve170
    Steve170
    Jan 25, 2005
    362
    28
    +37
    There's an option on the PS2 setup screens, where you have to select RGB or component (or at least there is on my 'old' style PS2). Have you done this?
  3. Throttle
    Throttle
    Sep 28, 2004
    1,821
    Leigh
    +107
    yea there is a option on newer ps2 to select component rather than RGB on the Ps2 start up screen like the old ps2 ;)
  4. john<|>nhoj
    john<|>nhoj
    picture slightly better through component...
  5. phreak97
    phreak97
    actually, if your tv is any good, the picture will be a crapload better through component. it is on mine.
  6. danvitale
    danvitale
    Nov 18, 2004
    2,339
    63
    By The Sea
    +114
    I agree. The difference going from composite Scart to component on my 26" LCD was amazing.
  7. john<|>nhoj
    john<|>nhoj
    I have a screenplay 4805 projector.
    This is comparing the composite output with the component output using the lead supplied from Asia for £11 inc shipping.
    Hopefully my Xbox component lead (original MS version) will arrive shortly.
    Question:
    Will I see a big improvement going to a dedicated DVD for movies from the xbox with component on the Projector (about 2.2 metre image)?
