PS2 component cable not working with plasma, any ideas ??
Discussion in 'Playstation Forums' started by jamieuk23, Jan 31, 2005.
  1. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,173
    +26
    Ok I have this Component Cable Switch http://www.whitedog.co.uk/catalog/product_info.php?products_id=421
    and I have hooked up in the 3 component ports, on the switch
    1 = xbox > Hi Def component cable
    2= gamecube nintendo component cable
    3= PS2 http://www.tvcables.co.uk/cgi-bin/tvcables/XPP04.html
    when I switch to 1 the xbox comes on >> when I switch to 2 >> the gamecube comes on >> but when I switch to 3 I get no signal.
    I have tried plugging in the PS2 component cable direct to the plasma and I still cant get any type of signal.
    tried it with the orginal scart that came with my PS2 and that works fine, but I just cant seem to get a signal from this IXos component cable even thou its setup correctly.
    any ideas ??
  2. BALLISTIX
    BALLISTIX
    Oct 7, 2004
    116
    16
    Have you set it to component in the menu?
    If so I think you'll find it's your PS2 at fault,,how old is it?
    I have 3 PS2's all between 3-4 years old, none work via component cable (I've tried two different cables) all I get is an occasional scrolling broken picture with mostly a no signal message.
    I hear it's a software/firmware issue, I've not found out if it can be fixed yet, but have been told the newer silver PS2's are ok via component.
    Andy.
  3. bfrench
    bfrench
    May 3, 2004
    138
    surrey
    +3
    I bought one of these component switchers and the output
    marked '3' seems not to work properly. Having said that I had a dodgy
    component cable. I now have a monster gamelink cable and that works
    fine. The cable that did not work produce a picture that was very distorted and kept flashing on and off.
    Barry
