PS2 Component cable - does not work!!
Discussion in 'Cables & Switches' started by micol, Oct 29, 2004.
  1. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    I have just recieved my top-of-the-range Ixos XPP04 PS2 to Component cable and plugged it from my PS2 to my Component input on my Hitachi 42PD5200, but get no picture!!
    I'm pretty sure I have done nothing wrong. I have checked the settings on my plasma and all seem fine. To add insult to injury, I plugged my cheapo crappy component lead I bought earlier and that worked fine!
    Anyone elso had any similar problems or am I missing something??
  2. Gillykid
    Gillykid
    Mar 4, 2004
    212
    Warwickshire
    Have you setup the picture from RGB to Yr-thingy in the PS2 setup? If not put your regular Composite cable back in, go into system setup (boot without a CD) and change the settings. Shut down, replace the cable and you should be good to go! :cool:
    G
  3. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    Yeah, Done all that. I'm beginning to think it may be a faulty lead as my old cheapo component lead works fine.
  4. Kippers
    Kippers
    I am having a problem getting my Ixos component cable working on my ps2 aswell, dont have a cheapo one to try though - might be worth me getting one!
  5. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    I think there could be a bad batch of IXOS XPP04 cables doing the rounds. I'm still waiting for my replacement after I sent mine back! I'd suggest you do the same Kippers.
  6. Kippers
    Kippers
    IT WORKS!! I've managed to get a PS2 game on my plasma via Ixos component cable, but not with my PS2!!
    I have an original version 3 and it doesnt work, yet my friends new silver version does!!??
    Must be some incompatibility issues with the original ps2's?
    Do you have an original or early version?? If you can borrow someone else's new silver or slimline and try it you might find the same result as me!
    I'm pleased I got a picture now, looks noticeably less jagged but now I have to buy a new ps2!! DOH!!!
    :rotfl: :suicide:
  7. nemo
    nemo
    Nov 19, 2003
    406
    28
    +25
    There was a thread on this forum not long ago about PS2 and component incompatibility. Someone said that the model number of the PS2 had to begin with 5000xx.
    Personally I've got a newer PS2 and component works fine on mine.
  8. McPastry
    McPastry
    I have a US launch PS2, and both the official Sony and IXOS cables work great with it. Although I've found that with PS2 better picture = more jaggies!!!
