PS2 Broadband adaptop on new PS2
Discussion in 'Networking & NAS' started by CAS FAN, Oct 4, 2004.
  1. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,343
    2
    167
    The Wheldon Road end!
    +8,370
    Does anyone know if it's possible to set up a PS2 broadband adaptor on a new PS2 located at a different location to the one that it was originally set up on. To set up on central station you use temporary pin numbers provided with the adaptor set up disc. As I have already used the numbers in my first setup will I still be able to set up the adaptor again on the new PS2?
    Sorry if that sounds a little confusing :confused: but hopefully someone will know what I mean. :)
    Graham
  2. Alun
    Alun
    Sep 15, 2004
    2,604
    Praying to the God of Wind
    +243
    I just got a new PS2 and it didnt work at first, deleted all exsisting data on memory cards then put in access disc. Unfortunately I cannot find the insert with the numbers on,hence only got so far with the central station bit. But I can still play NFSU, THUG, and Burnout 3 no probs online.
  3. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,343
    2
    167
    +8,370
    cheers for the reply. I think I may need to get the central station thing working to play Socom 2 - might not though. Surely there must be someway of getting more temporary sign in numbers to register with.
  4. Alun
    Alun
    Sep 15, 2004
    2,604
    +243
    I have just logged in to Central station using my exsisting user name and password.
    There is an option within the settings where you can change the serial and model # of your PS2, but I have left mine alone and it works ok.
  5. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,343
    2
    167
    +8,370
    That's great, thanks for your help.
