ps2 black bar
-Jay-
Joined
Jul 26, 2002
Messages
4,934
Reaction score
125
Points
798
Age
44
Location
Kop End
hi guys is there any way of getting rid of the black bar down the right hand side of screen.
cheers
Heh, I take it this is via Scart? There isn't a way sadly since for most PS2 games (bar Sega ones and GT3 as a few examples) won't let you shift the horizontal or vertical axis at all... Which is rather annoying. When playing a 4:3 game on a widescreen TV though it doesn't matter as much. If your TV supports manual shifting then use it.
hopefully the tosh 36zd26 does allow you to shift because the black bar is a pain.
Yep, the TV allows you to shift the image horizontally only though... Plus on a widescreen TV running a 4:3 image its not so bad.
LG G4 OLED Best Picture Settings Out Of The Box - Filmmaker Mode!
Back
