PS2 and Virgin.net
Discussion in 'Playstation Forums' started by Dak, Jul 3, 2004.
  1. Dak
    Dak
    Sep 23, 2002
    251
    Chislehurst
    I have the PS2 and adapter plugged into my router, the disc in and am trying to set it up. It asks me if I usually use a password to log on...
    I have entered my log in and password but no joy! The green light on the back of the adapter is on so I think that says the hardware is ok.
    I have gone for auto on the dns thing.
    Help!
  2. Tetlee
    Tetlee
    Jan 21, 2004
    19,864
    Taunton
    +4,461
    Hi Dak,
    I had a similar problem when I first tried to connect my PS2 through my pc connection via crossover cable. In the end I changed the setting on the PS2 to tell it that I didn't require a password to connect and BINGO! (although I do require a password to connect my pc to the net, but I guess the problem for me was that my pc had already used the password to connect anyway and I was trying to share a connection rather than create a new one).
    Hope this helps.
    Good Luck! :smashin:
