ps2 and philips 32PF9986 problem
Discussion in 'Philips TVs Forum' started by dave04, Aug 16, 2005.
Tags:
  1. dave04
    dave04
    Ive had my 32PF9986 a few months firmware 2.3, have tried connecting PS2 to side connections.
    When ps2 loads a sound and audio comes for a few seconds, but then picture doesnt load only the sound.
    Tried different phono connection leads and these same leads on a normal tv and the cables where all fine.
    Xbox worked fine on 32PF9986 using side connection.
    Is there anything I could try? Or ask for a repair
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    My PS2 is connected this way too and it works fine. It's not the best way to do it, but it's adequate for my purposes.
    It sounds to me like you have a faulty connection on your yellow lead, either at the PS2 end or the TV end. Do some wiggling!
    Jimmy
