PS2 and 1080i
Discussion in 'Playstation Forums' started by danvitale, Feb 23, 2005.
  1. danvitale
    danvitale
    Nov 18, 2004
    2,340
    63
    By The Sea
    +114
    Hi all, with Gran Turismo 4 using 1080i, would I be right in thinking to enable 1080i via component, you would need something like this:
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=11319&item=8171728602&rd=1
    and then select the Component output in the PS2 options?
    Im just concerned that there maybe a situation like the Xbox where you need to soft-mod the console to get it outputting in the Hi Def format.
    Cheers to anyone for any clarification!! :thumbsup:
    Dan
  2. Pooon
    Pooon
    Dec 26, 2002
    7,366
    Canterbury, Kent
    +956
    AFAIK you will just need to buy a component cable to get 1080i out of GT4, plus you will need a display that will handle that resoloution as well.
  3. danvitale
    danvitale
    Nov 18, 2004
    2,340
    63
    By The Sea
    +114
    Excellent, Ive got both then (as long as I buy from the link). Thank you sir!
  4. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    Having read info from various places such as this I am led to believe because of our PAL 50hz as opposed to NTSC 60hz there could be a prob with the 1080i mode.
    You will have to trawl through the tons of info but im sure I read it somewhere, then again could be rubbish :rolleyes:
    Matt
