PS2 advantage (again)
Discussion in 'Playstation Forums' started by Lex, Feb 17, 2002.
  1. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Hi all.
    (I just posted this thread under 'General Hardware' by mistake, so I am re-threading it here!)
    Can anyone explain to me the difference between:
    DVD Region X
    DVD Advantage
    They are both for sale for the same price and yet (as far as I can tell) the Advantage includes Region X plus a lead and a remote. This seems strange to me - why would anyone buy the former, when you can get the latter for the same price? Is this right?
    Just wanted to check before I ordered.
    http://www.mx2.org/acatalog/MX2_org...sories_211.html
    Advice appreciated,
    Lex
    :confused:
  2. Gerry
    Gerry
    Oct 20, 2001
    251
    My Gaf
    +10
    I bought the DVD R X before I saw the other one with cable and remote included. Can't say I could determine any difference in what the DVD Discs did. Buy the advantage package and try it out if you do not like it you can always exchange. The DVD R X basically allows you to select a region from 1-6 and also allows you to playback DVD's in RGB without the green screen. As the advantage package comes with an RGB cable it must do the same.
