PS12 service menu
Discussion in 'Televisions' started by captain_h, Nov 15, 2003.
  1. captain_h
    captain_h
    Just got my Panny 32TXPS12 from JL. 1st impressions are really good - it has a watchable and detailed picture. Being a newbie I didn't expect just how much difference in picture quality I'd see just from different quality sources even on the same channel - great! DVD also looks exceptionally good.
    One slight niggle is what looks like a mild case of pincushion distortion, most easily noticable when the TV flips into 4:3 mode. I believe this might be a common "feature" of the TV model.
    So... can this be tweaked from the service menu, and if so is it safe to fiddle about with the TV in this way? Assuming it's a good idea, where are the access codes documented for this menu?
    Cheers and thanks in advance,
    Capt'n
