ps1 games onto psp
Discussion in 'Playstation Forums' started by john o, May 2, 2007.
  1. john o
    john o
    Feb 25, 2006
    75
    Can someone write some detailed intructions (step by step)on how to but ps1 games on to a psp and what programs are needed and links on where to get them.
    This would be very helpful if someone has time.
  2. Korum
    Korum
    Feb 19, 2005
    4,423
    Stockton-on-Tees
    +713
    Simply buy a PS3, buy the games from the playstation store and transfer them to your psp memory card.
  3. mroshaw
    mroshaw
    Jan 8, 2007
    560
    Guildford
    +39
    Ah, I was going to ask the very same thing!
    I have Tomb Raider, Dino Crisis and Fear Effect 2 original PS One games and have the latest DA firmware on the PSP. I believe that you can simply rip your PS One CD to an ISO image and whack it onto the PSP - the DA firmware should handle the rest. Otherwise, look on Google for 'popstation', which seems to be a bit more complex.
    My current problem is that I can't find anything to rip the PSOne disc to ISO - all the progs that I've tried (Alcohol 120, Nero 7, CloneCD, ISO Maker) write to proprietary formats or fail to rip to ISO as the discs are multi session.
    I'm going to research this further today and will post a response to the OP if I get an answer. If anyone knows off the top of their heads how to rip a standard ISO image from an original PSOne disc, that would be a great head start!
  4. mroshaw
    mroshaw
    Jan 8, 2007
    560
    Guildford
    +39
    A quick search of the forum seems to reveal an answer:
    To the OP, if you do a Google search for 'rip psone iso for psp gamerspress', you'll find a Wiki site that contains full step by step instructions.
    I'm going to try it later on and will report back.
  5. lovelldr
    lovelldr
    Jul 19, 2006
    2,287
    63
    East Midlands
    +148
    yup, everyone has a spare £400 in the back burner just to do something simple like that... Thanks for the nice helpful comment...
  6. mroshaw
    mroshaw
    Jan 8, 2007
    560
    Guildford
    +39
    That's what I thought... :rolleyes:
  7. john o
    john o
    Feb 25, 2006
    75
    Thanks for that I will try later, do let me know how you get on. cheers
  8. readingfanman
    readingfanman
    Apr 22, 2006
    535
    28
    Reading
    +37
    Re-wrote the entire guide since the old one was over 3 months old and there is a better way to convert your PSX Games.
    This guide will work on 3.03OE-C, 3.10OE-A' and 3.30 OE-A, and quite possibly every future version of custom firmware...
    If you have 3.03 OE-C and you are using 'PAL' region games you will need to tick the "Screen Height Fix" box before converting.
    If you have 3.10 OE-A' / 3.30 OE-A then you don't need to use the 'Screen Height Fix' as those firmwares have PAL region support.
    The compatibility of the PSX emulator is fairly high but there may be a few games that won't work properly.
    Examples: Game plays too fast, audio and video out of sync (not matching up), missing graphics / audio etc.
    A game that doesn't work on 3.03 OE-C might work better on 3.10 OE-A or 3.30 OE-A and a game that works perfectly on 3.03 OE-C might not work too well on 3.10 OE-A or 3.30 OE-A. This is because the PSX emulator program is being changed / tweaked by Sony to work with different games and some of these changes 'break' the compatibility with games that worked before.
    If you have 3.03 OE-C or 3.10 OE-A' you can use the 'Popsloader' plugin to load the emulators from different firmware versions.
    example: So you can load the 3.10 OE-A' PSX emulator when you have 3.03 OE-C custom firmware installed.
    A 'popsloader' plugin for 3.30 OE-A is being worked on at the moment,
    The 'popsloader' plugin for 3.03 OE-C / 3.10 OE-A is incompatible with 3.30 OE-A so it will not work.
    This guide will show you how to convert a PSX game from a CD to a PSP EBOOT.
    Required Files:
    Magic ISO Maker:
    Download: http://www.zshare.net/download/magiciso_setup-exe.html
    Mirror : http://www.sendspace.com/file/4xqrm4
    Magic ISO Website : http://www.magiciso.com/download.htm
    Popstation GUI v3.00 (Beta)
    Download: http://www.zshare.net/download/popstationgui-v3-00-rar.html
    Mirror : http://www.sendspace.com/file/4802e8
    Installing the Program files
    Installing Magic ISO Maker
    1. Download the 'Magic ISO Maker' Installer and save it to a folder on your computer.
    2. Run the Install program, click 'next' four times and the program will start installing.
    3. Once the program has been installed press the 'Finish' button.
    Installing Popstation GUI v3.00
    1. Download 'Popstation GUI v3.00' and save it to a folder on your computer.
    2. Popstation doesn't have an installer, so extract the RAR file to any folder on your computer.
    Making a Cd Image of your PSX Game
    1. Start 'Magic ISO Maker' and click the "Try It" button on the 'Register Screen'
    2. Insert your PSX game into a Cd or DVD Rom drive.
    3. Click the 'Tools' Menu and select 'Make ISO from CD/DVD Rom'
    4. Click the 'Make CD Image' option.
    5. Select the CD / DVD Rom drive you inserted your PS1 CD into.
    6. Choose 'BIN Image File' from the drop-down box.
    7. Select where to save the CD Image to.
    8. Click the OK Button and the CD Image will be saved to your Hard-Disk.
    This may take a couple of minutes...
    9. Once the image has been saved, you can close the 'Magic ISO' Program.
    Converting the Cd Image to EBOOT format
    1. Start the 'Popstation GUI' Program.
    2. Select the 'CUE' file of the Image you saved earlier.
    3. Choose the folder where the EBOOT.PBP file will get saved to.
    This will automatically get filled in with the Name of the Image.
    4. Choose the compression level, this is normally set at '9' (Best compression).
    If the game is running slow then try re-converting with less or no compression.
    9 is the best compression
    1 is the worst compression
    0 is no compression
    5. The name of the game should show in the Game Title. If the game title is wrong
    Press the 'Select' Button and choose the correct game name.
    6. I recommend leaving both of these options unchecked.
    Fix Screen Height: If the bottom of your games are cut-off then you will need to tick this.
    Fix Graphics: If your game has graphics corruption, this option may fix it.
    7. Press this button to show the 'Customize' options.
    ICON0: If you have a custom icon for the game then you can add it in here.
    Image size: 144 x 80 Pixels, 32 bit color, PNG format -- ICON0.PNG Sample
    PIC0.PNG: This is the 'Information' image, which is usually 'transparent'.
    Image size: 480 x 272 Pixels, 8 or 32 bit color, PNG format -- PIC0.PNG Sample
    PIC1.PNG: This is the Background Image shown when you select the game.
    Image size: 480 x 272 Pixels, 32 bit color, PNG format -- PIC1.PNG Sample
    ICON1.PMF: This is an 'Animated Icon' which can be used instead of the ICON0.PNG
    SND0.AT3: This is the 'Sound' the PSP will play when the game is selected.
    WARNING.PNG: This is the 'screen' you see while the PSX game is loading.
    Image size: 480 x 272 Pixels, 32 bit color, PNG format -- WARNING.PNG Sample
    Make sure you have the 'WARNING.PNG' box ticked as it is needed for all games.
    If you don't have any 'custom image files' then untick all the boxes except for warning.png.
    8. Click the 'Go' Button.
    If you get this message below, click the 'Yes' button.
    Not all games require will a PAL to NTSC fix, Your game will need fixing if the bottom of your game is 'cut'
    If it is then you will need to reconvert again, but tick the 'Fix Screen Height' Option box.
    If you have selected the PAL to NTSC fix you will get this message. The NTSC to PAL fix will be
    reverted back once the program has finished converting so choose the 'Yes' option.
    9. Your Game will start getting converted to the PSP Compatible 'EBOOT.PBP' format.
    (There is a bug when using Vista, the 'Bytes Written' doesn't count up)
    10. After the conversion has finished, you will be asked If you want to transfer the game to the PSP
    Click 'No' since we will manually transfer the game to the memory stick in the next section.
    Transferring the Converted Game to your PSP
    1. Connect your PSP to your computer using a USB Cable and activate a USB connection.
    2. Open the Folder where you saved the game in the 'Popstation GUI'.
    If you didn't change the folder it will be in the folder with the CD Image.
    3. Select the folder and choose 'Edit -> Copy'
    4. Open your PSP Memory stick Drive Letter (e.g E:\)
    5. Open the 'PSP' folder and then the 'GAME' folder.
    6. Click 'Edit -> Paste' and this will copy the game over to your memory stick.
    This is how your 'Memory Stick' layout will look like after you have copied the game onto it.
    7. Close the 'USB Connection' and disconnect the USB cable from your computer.
    8. On your PSP, go to the Game menu, select 'Memory stick' and press 'X'
    9. On the Game Menu you should see your PSX Game listed
    Highlight it and Press 'X' and your PSX game will start.
    It may look like your PSP has frozen, just wait a few seconds while the PSX Game loads.
    How to tell if a game needs the 'PAL to NTSC' fix
    In the image below the game has a big black bar at the top of the screen and the bottom is cut off.
    This game will need the 'Fix Screen Height' box to be ticked before you click the 'Go' button to convert it to an EBOOT.
    This is the fixed game, The black borders should be the same size on the top and bottom.
    Credit to The Android at pspiso.
