stuartk
Established Member
I have recently bought a PS Audio Sprout amp as I’m reverting back to stereo having had an AV System using a Denon 4100.
The sound it gives is good but the Denon sounds not far off it without the Schitt DAC.
I also bought a Schitt Modi DAC and a Bluesound Node 2i connected to Focal Aria 926 speakers.
I feel the amp has to be turned up a lot before I get a decent volume.
My room is 20ft square.
Should I get a power amp using the RCA out of the Sprout to connect to the power amp,
is that even possible?
Any help appreciated as I’m not used to 2 channel, DAC’s etc.
Stuart.
Stuart.
