PS 7 - File Browser problem
Discussion in 'Photography Forums' started by martynk, Apr 26, 2005.
  1. martynk
    martynk
    Hello there. I'm using PS 7 and can only get the File Browser window to open in the top left corner of the screen - no problem until a couple of days ago. Can't drag larger than about 1/8 of screen size, which makes me think it's already in normal view but not fully visible, and can't get to the title bar to move it. Can anyone help? Thanks.
  2. RobertP
    RobertP
    Nov 21, 2002
    522
    19
    Woodford Essex
    Tried std windows shortcut keys? alt-space-x for maximise ?
  3. martynk
    martynk
    Thanks RobertP. Yes, tried this and a few other options, including reinstall, but it doesn't help.
  4. RobertP
    RobertP
    Nov 21, 2002
    522
    19
    Woodford Essex
    Window positions are saved in the registry so its conceivable it would survive re install.
    If you are right about just needing to move the window alt-space-m gets you into window move .... then use the cursor keys.
  5. martynk
    martynk
    Tried this, still no joy, but thanks anyway. Might have to resort to another reinstall, with a registry edit.
