PS 2 to Infocus 4805
Discussion in 'Playstation Forums' started by simch, Sep 9, 2005.
  1. simch
    simch
    Sep 7, 2005
    103
    16
    Which is the best way to connect my PS2 to a ceiling mounted infocus 4805 projector. I am running component inputs to it through the ceiling and using the video switching on my Yamaha 757 se amp to switch dvd and sky+ (via svideo) signal to my component lead to the projector. Can I do the same with the PS2? I would also like the PS2 sound through the 5.1 amp of course.
    Also, thinking of an xbox360 soon. I know the 4805 is not hi def /hi res, but how would this console coneect up best?
  2. binbag
    binbag
    Jun 16, 2004
    1,717
    North Kent Coast, SE UK
    +81
    Use s-video to check out if you can live with the signal delay when playing. If this doesn't bother you then upgrade to a component lead.
    Most stuff looks best on 480i/p on the 4805.
