PS/2 Socket for Tv-out?
Discussion in 'Desktop & Laptop Computers Forum' started by GTSkater, Jan 5, 2004.
  1. GTSkater
    GTSkater
    Feb 11, 2003
    38
    9
    London
    Got a GeForce 2 MX Video card with a TV out socket that looks very similar to a PS/2 port for a PC Mouse or Keyboard.
    See picture [​IMG]
    Any idea on what cable I need for this? Where to buy it?
    Any suggestions on how to hack a cable to take the signal to a Scart socket capable of RGB, S-Video or composite would also be appreciated.
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    That's an S-Video socket, so an S-video-scart lead should do the trick.
  3. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    Looks similar to s-video, but seems to have more pins (6) and a different locator. I enclose s-video image:. I have a similar one on the back of my laptop for TV connection, so would need a special cable, usually supplied with the card
  4. GTSkater
    GTSkater
    Feb 11, 2003
    38
    9
    London
    I think thru some messing about and playing we've established it's a hybrid S-Vide socket. One of the extra pins is for composite we think, and the other one doesn't do anything.
    We're going to grab a PS/2 cable and an S-video cable and do some hacks to see if it works.
  5. Underscore
    Underscore
    Yep, got one of those on my Radeon. S-video plugs straight in and there is an adaptor cable supplied that gives the composite output instead, if needed.
    _
  6. Spaced
    Spaced
    I'm the other bloke trying to sort this cable out :)
    It's basically a PS/2 socket, with S-video and Composite. Normal TV-out sockets have 7 pins, with one not connected. This has all the pins connected, with pins 5 and 6 being for composite. Unfortunately, S-video does not fit into the socket, so I'm gonna somehow have to rewire a PS/2 cable with S-video. Unless anyone knows where to get one...
  7. mjn
    mjn
    May 24, 2001
    18,379
    Herts, England
    +5,464
    looks like the connection on the old Creative Labs Dxr2 DVD decoder card. 6-pin DIN on one end and composite and s-video on the other. Contact Creative, probably get one for free!!
  8. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    mjn thats exactly what it is:)
    you are suposed to get an adaptor with that card. your right it is an s-video/composite hybrid. Basically, you should have had a lead tahat plaug into that with both s-video and composite sockest on the other end.
    i got one with my gf4 440mx that uses the same socket.
  9. Spaced
    Spaced
    I'm gonna try and pester Creative, you never know! James, what make is your GF4 440MX? I suspect this card is a Leadtek, but it's not marked on it anywhere. Any idea how to tell?
