ProV+ Progressive Scan Video Converter
Discussion in 'Projectors, Screens & Video Processors' started by Guttee07, Sep 18, 2003.
  1. Guttee07
    Guttee07
    Sep 13, 2003
    64
    Runcorn Cheshire
    ProV+ Progressive Scan Video Converter is it worth me getting one of these for my panny pt ae200 to improve the picture quality.
    Is there anything else i can do to get optimum quality
    mike
  2. gingercat
    gingercat
    Nov 19, 2002
    490
    Lancashire, UK
    +27
    When you say "to improve the picture quality", what video source are you hoping to improve, because my experience of the original ProV (of which the ProV+ doesn't upgrade in terms of deinterlacing etc.) with my AE100 was that it just introduced lip-sync problems, and made the image look rather nasty and jerky. The Panny PJs seem to have pretty good internal de-interlacers and scalers (well, better than the ProVs anyway) so unless you're shelling out for a more expensive de-interlacer/processor, I don't think you'll see that much improvement.
    I can however highly recommend going the HTPC route for best possible picture quality, there you really will see a huge improvement in PQ.
  3. ruffrider
    ruffrider
    hi i was just gonna buy one of these when u mentioned the lip sync issue could u please elaborte for me ?
    thanx
