prov connector box from keene,Does anybody use it
Discussion in 'Projectors, Screens & Video Processors' started by RATMARK, Apr 3, 2003.
  1. RATMARK
    RATMARK
    im looking at buying one of these for future connection to a sanyo pj
    Has anybody got / used one who could offer me some advice,or any other box to connect to pj
    i need to connect
    free to air
    satalite box
    playstaion 1
    and then i guess run a vga cable to the pj from the prov box,can i also route my pc thro this box due to limitations of connections on back of pj
    i prefer not to run any video signals via my a/v amp (ie svideo )
    Marantz sr5200
    dvd direct to pj cia component
    any advice much appreciated:confused:
  2. Jonny1973
    Jonny1973
    Pro-V connector box???
    The Pro-V converts S-Video or Composite to VGA (1024x768). VGA by it nature is progressive scan. The Pro-V only has one s-video and one composite connection.
    The connector box is really your amp. I use my amp to select the source (dvd or sky) which is then passed by S-video to the Pro-V and VGA out to the projector.
    If you are using ordinary component for dvd (not progessive scan) then I would use the Pro-V via S-Video. The pro-v cannot convert component.
    Search on these forums for pro-v and you find lots of threads which will answer all your questions.
