PROV + Box
Discussion in 'Plasma TVs Forum' started by Dr Downey, Aug 25, 2004.
  1. Dr Downey
    Dr Downey
    Jan 12, 2004
    124
    19
    Cheltenham
    Hi All,
    Does anyone know where I can get a ProV + box from :lease:
    All I seem to be able to find are links to user manuals.
    Cheers!
  2. Stimpy
    Stimpy
    Sevenoaks can order it for you. That's were I got mine.
    There is an alternative (about the same price), the Vivid VTB100 (I think)
    this has component as an aditional input.
    However you may want to compare quality. In my case with my old LG plasma the vivid gave much worse results using component comparted to S-vid on the Pro-V,
    but this may have just been an issue with the screen.
  3. Dr Downey
    Dr Downey
    Jan 12, 2004
    124
    19
    Cheltenham
    Thanks for the info Stimpy :)
