Proto CCF for Sony HS20 PJ
Discussion in 'Home Cinema Control & Remote Controls' started by Eakley, Dec 23, 2003.
  1. Eakley
    Eakley
    Anyone out there got a Pronto CCF for a Sony HS20? I got one for an HS10 from remotecentral, but I get no response from the HS20.
    Failing that, anyone know what the IR codes are for an HS20?
    Thanks.
  2. paulw77
    paulw77
    Nov 18, 2000
    529
    Wigan
    +19
    Can't you just do your own ?
  3. Eakley
    Eakley
    Just trying to save my self some time.:rolleyes:
  4. ozdvduser
    ozdvduser
    Apr 21, 2003
    170
    At The Track or Melbourne Victoria Australia
    +3
  5. ailean
    ailean
    Did you get anywhere with this?
    I've tried the RemoteCentral and Jenkins ccf's as well as all the Sony Projector modes in Nevo (using a PDA with Nevo and TVRemote pronto emulation).
    So far the only responce I've had is a power on without enabling the Lamp!!!! :(
    The remote has the same model number on the front as the HS10 but it's looking like it might be different somehow.
    I'll try learning stuff off it at the weekend but I really wanted the direct codes for on/off and inputs. :(
  6. Eakley
    Eakley
    PM me your email address and I'll send you through what I've got. Most of the codes work, but there are a few that don't. Unfortunately the version of RC5000setup I am using has a habit of crashing under WinXP when I try and learn a code.
    As well as the CCF, I've got a word doc with the codes, from the above web site.
