Proto Advise Please...................
Discussion in 'Home Cinema Control & Remote Controls' started by darren7, Mar 4, 2003.
  1. darren7
    darren7
    Hi guys and girls.
    I have had a pronto for some time now, I have only just got round to getting it out of the box, I have looked through the manual, it all looks pretty tough going.
    Now I have sky+, and a Sony proj and a Pioneer amp I would like to operate.
    I have looked on the Remote central site as well.
    My Question is what are the best steps to take and the best place to start.
    I no that I need ccf file and all that. I have had a quick look and set it to learn with the sky+ remote and the projector remote but all it does is say fail.
    Am I doing something wrong, do I have to this like this or can I download the whole configs in one go, I see that there is pronto edit on the supplied disk, this may be an old version though.
    Thanks people.
  2. darren7
    darren7
    Anyone??
  3. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
    have a look at the following website, it has lots of CCF's to choose from (to save you work!!!) and a really good FAQ:
    www.remotecentral.com
    JJ
  4. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,416
    North East Scotland
    +65
    Darren7 - this is really stupid, but my first mistake when trying to program my new Pronto was that I hadn't noticed the "Learning Eye" and I spent 15 minutes pointing my remotes at the "Transmitting Eye" at the front!
    The reason I did this is because I previously had a Sony commander which has only one eye - at the front.
    Doh!:blush:
  5. darren7
    darren7
    so first learn the codes? yes
    then get the ccf`s , is this the correct order or is there a better way, or a different order to do things.
    D
  6. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,416
    North East Scotland
    +65
    I downloaded the ccf's - then edited the layout to my preference, using prontoedit. Afterwards I learned the codes from my existing remotes and programmed the hard buttons.
  7. darren7
    darren7
    ok guys I will have to now download it and have a go,
    its funny really I got a cd with my pronto that says pronto edit software, when you look on the cd, all it has is a load of pdf files ie: france , german ,ect and no exe files.
    dont really understand the bit that people say about the alias buttons and the dummy panels but hey I have to give it a go.
    cant find any ccf files for the Pioneer vsx 2011, anyone ?
    thanks all
  8. kron
    kron
    Feb 24, 2003
    1,262
    Plymouth
    +135
    Yea my cd didn't have the pronto edit exe. on it either :shrug:
    A dummy panel is a basic blank panel just add some buttons to it and learn all the IR codes for say sky+ for each button (you can get them from someones ccf) These buttons become aliases for the buttons on your main sky+ panels . Basicaly instead of having to learn every button on diferent panels over and over again you just right click on the button you want to program and click alias ,scroll down the list of devices till you get to your dummy panel and click on the relevant button.
    See if you can get ccf's for all your kit then take the codes from them you will also get a good idea of how the layout and stuff is done just by experimenting with them.
  9. kron
    kron
    Feb 24, 2003
    1,262
    Plymouth
    +135
    I couldn't get the codes for my receiver either ,no sweat though it's easy to learn them with your exsisting remote.
  10. ISHANTY
    ISHANTY
    Sep 13, 2002
    529
    3
    28
    UK
    +58
    try using a stylus and it should progam it
    i know this for i was pulling my hair out trying to progam my one but then i thought that if i treated it like a pda maybe it would recognised the keys,u see the screen is really sensitive and when you press the keys with your fingers it sometimes doent work
    P.S AND YES I DO HAVE SKY+(and its all fully progammed)
