ProSieben HD Channel Number
Tony B
Established Member
Does anyone know what Channel number is used by ProSieben HD?
P7HD seems to have disappeared from my EPG.
Having, at last, got my Humax working (reasonably) I am getting bored with Canal + HD Demo loops and want to watch something proper!
TIA
Tony B
G
gin-ja
I think you may find that they are now only showing there presence on MPEG4 receivers so unless you are lucky enough to have one they are not seen by standard digital receivers. :thumbsdow
gin-ja
Tony B
Established Member
gin-ja
I have an MPEG4 receiver (at last) - Humax PR-HD1000.
I can see P7HD again in the EPG and receive the pictures in HD.
Weird stuff 1 - one moment it was at channel 600+, then it re-appeared in the EPG at 184 (I think?).
Weird stuff 2 - HD in 4:3 format? What are they thinking about?
Off to do some more satellite hunting now.
Stephen Neal
Isn't the 4:3 stuff mainly SD upconverted to HD? AIUI Pro7 HD is the HD version of the regular Pro7 channel, carrying the same schedule.
Shows that Pro7 have in HD are broadcast in HD on the HD channel, but all the other SD shows that Pro7 show are upconverted and also broadcast on the HD channel. If the source show is 4:3 it will be shown 4:3.
Native HD production is not in 4:3 - the only HD 4:3 material that is likely to be broadcast is new transfers of older 4:3 movies. (These, being shot on film, have enough resolution in the original film grain to benefit from an HD transfer over an SD one)
K
kuba2222
@Tony B
Try Eutelsat 7E 10879V SR17360 3/4 . HD1 is Free to Air at the moment. Much better then demo loops:smashin:
Tony B
Established Member
kuba2222 said:
@Tony B
Got it! :smashin:
There must be an easier way of finding "non-standard" satellites with this box though, it would have taken me ages without the freq/SR info, so many thanks.
I have set the box for MPEG2 and it works (surprised it is not MPEG4), but the images are a little jerky, and freeze every so often. The signal strength and quality are fine (40+ and 100%).
Are you getting this effect too?
Rgds
Tony B
K
kuba2222
It is MPEG4 but DVB-S not S2 . Unfortunately it's test transmission and I have a feeling that thay really testing. Sometimes picture is great, sometimes not. Last week picture was dissapearing every 2 minutes and to get it back i had to reboot receiver, so really unwatchable. On Sunday it was all great, I was watching euro2004 footy and some other stuff :smashin:
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
