Proporta products in London
Discussion in 'Headphones, Earphones & Portable Music' started by mrflabby, Jul 19, 2005.
  1. mrflabby
    mrflabby
    Jul 8, 2005
    53
    11
    Hi.
    Is there anywhere in London I can buy the Silicone Case (Sony HD5) and Advanced Screen Protector (Sony HD5) - That is other than from the online proporta shop?
  2. Hrochnick
    Hrochnick
    Apr 28, 2005
    369
    Brno
    +9
    Try the Sony Centres, that's where I got my silcon case from.
  3. mrflabby
    mrflabby
    Jul 8, 2005
    53
    11
    Thanks!!
    Does the silicon case cover the screen? Would you recommend a screen protector?
  4. recsnmisc
    recsnmisc
    Jun 15, 2005
    188
    Portugal
    I asked the same question in another thread. Answer is no. It doesn't cover the screen, and so I'm getting some more screen protectors to go with it.
    I would recommend the OverlayPlus ones. Can't stress enough how much these protector rock. Got some for my Sony PSP. Crystal clear. Can barely notice theyre there. Durable. Just like a brand new screen. No other brand can beat these protectors quality-wise (believe me I tried a few). Never bought another brand since.
    http://www.overlayplus.co.uk/
  5. DrNic
    DrNic
    Which version did you buy for the HD5? Did the (ahem!) iPod one fit the screen?
    Nic
    EDIT: Okay you can ignore this as I've found the HD5 one!!
