'Proper' engineer needed........
Discussion in 'General TV Discussions Forum' started by Marco, Sep 28, 2005.
  1. Marco
    Marco
    I have a Sony KV36FS70 CRT.
    Recently whilst trying to adjust the geometry through the engineers menu, which I had relative success with, I have committed a cardinal sin:
    I hit reset whilst in the colour menu which has resulted in an awful colour range that I am told can only be factory adjusted.
    I’m sure there must be a ‘proper’ engineer out there with the equipment to put the colour settings to blueprint.
    Can anyone point me in the right direction or advise as to the next step.
    This was a fantastic TV but I’ve muffed it up.
    HELP!
  2. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,305
    +100
    IF you didn't make note of the settings before hand you're probably stuck..... however most Sony TV's have a default setting alongside each adjustment which if they havn't been reset to these then this would be a good starting point.
    Also there are a set of 2 digit default codes that can be entered that relate to one thing or another at the TT prompt... however I'm sure they won't be exactly the same for each model of Sony TV... so unless you know them it may actually end up making things worse.
  3. CTT
    CTT
    Sep 3, 2004
    77
    How did you access the engineers menu as I have the same TV and it also has geometry problems.
