ProntoProEdit v1.1.3.....please help before something gets broken!!
Discussion in 'Home Cinema Control & Remote Controls' started by mjn, Jun 24, 2005.
  1. mjn
    mjn
    May 24, 2001
    18,253
    Herts, England
    +5,277
    Got a really werid problem with ProntoProEdit, when i open up my saved PCF, all the graphics are "corrupt", take a look at the screenshot.
    But if i go back 5 versions of my design all is ok!
    But if i download the latest version direct from the remote, i have the exact same problem!
    Anybody any suggestions!
    PS....It all used to work!
  2. mjn
    mjn
    May 24, 2001
    18,253
    Herts, England
    +5,277
    Just found a new version of the software has been released, so will try that as well.
  3. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,937
    Manchester, England
    +81
    have a look for tonto - much better than pronto edit IME.
  4. vizslaraner
    vizslaraner
    Dec 13, 2003
    424
    Hereford
    A known bug in ProntoEditNG, ProntoProEditNG and Marantz Wizz.It 9.
    Quite rightly, the advice when creating your program is to save regularly. It would appear though that, for some reason or other, saving too often in one session corrupts the System Page graphics.
    Up until now the only solution was to continually monitor the system page and once corruption appears, shut it down, reopen and return to the last “clean” saved version (delete the corrupted one). Now, however, I believe the new version of ProNG may have overcome the problem; and I’m hoping the updated version of Wizz.It (due later this year) will do the same.
    I suppose one could create a CCF in Tonto and import it, but there is no direct version for the NG range.
  5. mjn
    mjn
    May 24, 2001
    18,253
    Herts, England
    +5,277
    Well i updated to the new version and all is ok so far, but as expected it couldn't recover my corrupted versions.
    Must say, the new software is a big improvement!
