prontopro & Sky+ codes
Discussion in 'Home Cinema Control & Remote Controls' started by Mario Nicholas, May 10, 2003.
  1. Mario Nicholas
    Mario Nicholas
    Apr 2, 2002
    820
    Surrey
    +86
    I am experiencing problems using the codes learnt direct from the Sky+ remote.
    If I hold the pronto 1M away from the dinky link it works fine, any further no response - But the original Sky+ remote works perfectly from over 6M away!
    This is a problem i've experienced on two sites now & equipment is ruled out...
    Can I get the code on a CCF file & merge it in at full power?
