Prontoedit4 problem
Discussion in 'Home Cinema Control & Remote Controls' started by Timh, May 1, 2002.
  1. Timh
    Timh
    Sep 14, 2000
    5,169
    2
    3
    Altair-4
    +285
    I have just downloaded PE4 but on installing it tells me..
    The installation package cannot be installed by the windows installer service. You must install a windows service pack that contains a newer version of the windows installer service.
    I popped over to microsoft to download one and it says if you are running Win98 second addition, which I have, there is no need to install the service pack
    :confused:
    Can anyone please help? :(
  2. baldy2
    baldy2
    If you go to http://nortonweb.cnet.com/ you can have your system scanned for the latest updates and upgrades using the CNET CatchUp software. BTW It's free! :)
    Oh and AFAIK there is no spyware being installed when using this service.
    (to check for any spyware go to http://www.lavasoft.nu and download Ad-Aware)
    Hope this helps!
    Ron
