pronto????????
Discussion in 'Home Cinema Control & Remote Controls' started by grahamricho, Feb 12, 2002.
  1. grahamricho
    grahamricho
    Oct 29, 2001
    702
    York
    +13
    i have the files on my desktop how do i get them into the pronto edit?????????thanks
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Open them within PronotEdit software using File Open options.
    Also, if you have Pronotedit installed correctly you can just double click on the ccf file and it will load up within Prontoedit.
