pronto
Discussion in 'Home Cinema Control & Remote Controls' started by dood, May 23, 2001.
  1. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    I have just ordered my 2meg pronto from letsautomate and later discovered that it doesn't include the docking station. Unfortunately it costs 25 quid to ship it to me so I'm wondering whether to order the dock separately. My questions: can I link the pronto to my PC to use prontoedit etc without the dock? If so is the dock simply a battery recharger? If the dock is necessary for the PC link, and I choose not to get it, will I be able to do any fancy work on the pronto?
  2. dUnKle
    dUnKle
    Jan 1, 2001
    15,473
    +2,381
    It is just a charger as long as you get the PC LINK leads ( which come with the remote NOT the docking station ) then you will be fine.
    You will need however to download the software
