Pronto TSU3000/ RU950 change default settings
Discussion in 'Home Cinema Control & Remote Controls' started by axs1544, Sep 8, 2004.
  1. axs1544
    axs1544
    Sep 3, 2004
    11
    Just a quick query for anyone with a Pronto TSU3000/ RU950
    I am thinkin of buying the American version (tsu3000) as have found it cheaper than the european (ru950) ... the only differences are the rf freuqencies...loaded codes for models and default settings
    Just wanted someone to confirm that you can change the default settings for european use and codes etc....pretty confident myself as have checked the net etc
  2. Liverpooltiger
    Liverpooltiger
    Sep 12, 2004
    308
    Wirral, UK
    +15
    As the happy owner of a TSU 7000, I can assure you that you will be able to use your american spec R/C in the UK. The US & UK units are identical in every way- (Both made in Holland )- except for the RF frequencies. However, do not worry, the unit can search for your codes anyway, if they're not there by default. :thumbsup:
