Pronto TS1000 Logo help
S
spinak
Hello all! I own a Pronto TS1000. I have had it for about 3 years now. I am trying to track down B&W HD channel logo's. I looked on remotecentral.com and found only color logo which will not work on the TS1000 as you know.
Can anyone help me with this?
N
nealgs
can you not convert the color logo to B&W - does the T1000 have greyscales?? can't remember if so, then converting as mentioned will probably work ok.
Gary
ta1
Yep, just save as a greyscale bitmap and load into the software.
If you're having problems let me know.
Ta1
