Pronto to Marantz
Discussion in 'Home Cinema Control & Remote Controls' started by Shoka, Apr 11, 2003.
  1. Shoka
    Shoka
    Jan 10, 2002
    4,327
    Surrey
    +239
    Is it possible to convert a pronto CCF into a Marantz CCF or will they work on each other OK?
  2. Loada
    Loada
    Mar 4, 2003
    585
    Guisborough, North Yorkshire
    +48
    As far as I know it is possible. The Pronto and Marantz RC5000 remotes have slightly different firmware features e.g Pronto has timers and beeps, Marantz has back-jumps, but I believe that the different editor software applications just throw away any CCF components that are not compatible.
  3. Shoka
    Shoka
    Jan 10, 2002
    4,327
    Surrey
    +239
    So if I download a pronto ccf and open it in touch screen edit it should just automatically get rid off the stuff I cant use and replace it with the marantz alternative?
  4. Loada
    Loada
    Mar 4, 2003
    585
    +48
    Yes, I think so. Try it and see. If not, you can use something like Tonto to load in the CCF and perform the conversion for you (save it as a different format).
  5. JurgenNL
    JurgenNL
    Jun 12, 2002
    282
    +20
    I have used different Pronto ccf's for my Marantz 5000i and I haven't undergone difficulties. E.g. for the Loewe Aconda I tried al the ccf's for the Pronto's en Marantz which I could find on Remote control (to get more codes and examples for the layout).
    Jürgen
