Pronto RU980 vs TSU7000
Discussion in 'Home Cinema Control & Remote Controls' started by Member 231429, Feb 2, 2005.
  1. Member 231429
    Member 231429
    Oct 14, 2004
    3,279
    +564
    Are there any reasons why I couldn't use the TSU7000 in the UK ?
    Such as voltage or RF issues.
    Are there any differences between the models or is it just badging to get a higher price off us in the UK ?
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
    To answer your question, no not really.
    Do a search on 'tsu7000' here on this remotes forum and you will find lots of info on using the TSU7000 in the UK.
    In summary:
    Yes they are essentially exactly the same unit.
    If you want to use RF, you need to get the RFX6000 adapter and not the UK one.
    You can use an appropriate UK mains adapter/coverter to power the docking station.
    JJ
