Pronto RU980/00 and Remote Control Sockets
Discussion in 'Home Cinema Control & Remote Controls' started by JimBobUKuk, Sep 21, 2007.
  1. JimBobUKuk
    JimBobUKuk
    Oct 23, 2005
    108
    +4
    Evnin all
    Wanted to ask a question. I have these Remote sockets.
    The sockets run on 433,92 MHZ but i think they r RF
    Can some one point me in the right direction of what I need to add these to my pronto?
    Thanks in advance
  2. stoobie
    stoobie
    Jun 3, 2006
    444
    Exeter, Devon
    +78
    In theory your Pronto will control the RF sockets but it is not as easy as it could be! The Pronto RF was designed simply to run the Philips IR extender using RF. It just so happens that here in Europe the RF is the same as the RF for other remote controllable items such as sockets so you can use it for that as well.
    What make are the sockets? there maybe someone on remotecentral who has managed to get your type working with the Pronto.
    If they were X10 sockets you'd be in luck because i could help with the codes but if they are some other, you may have a problem! It will most likely be trail and error with you having to load all the possible RF codes into your Pronto and trying each in turn.
    Let me know the make and model off the lables on the sockets and off the control that came with them and I'll see what i can find!
    Stoobie
  3. JimBobUKuk
    JimBobUKuk
    Oct 23, 2005
    108
    +4
    Stoobie
    on the remote is says Model TR-502MSV
    Libra GMBH
    the Sockets themselves are Model RC:710
    The Dimmer socket is Model RC:710DX
    Thanks for your help
  4. stoobie
    stoobie
    Jun 3, 2006
    444
    Exeter, Devon
    +78
    Are these the ones you have? If they are, it seems that you can teach the socket from your remote.
    http://cgi.ebay.co.uk/BNIB-x4-Remot...8206608QQihZ017QQcategoryZ50587QQcmdZViewItem
    I don't know of these sockets and a quick search of my usual sources doesn't help with using a Pronto with them. Does the user manual have any information on how to set them up with the remote that comes with it, because if you teach the socket from the remote, I might be able to give you a Pronto PCF to try.
    If you can scan the English pages of the user manual and email them to me that would be a great help!
    Stoobie
  5. JimBobUKuk
    JimBobUKuk
    Oct 23, 2005
    108
    +4
    Hi yes u program from the remote, it says u hold the teach-i button on the remote while pressing the on button for either 1 2 3 or 4 depending on the socket. it also says that about the dimmer socket too
    if u could help in any way i would be most gratefull
    by the way lidl have these for sale for £9.99
    sweet!
  6. JimBobUKuk
    JimBobUKuk
    Oct 23, 2005
    108
    +4
    STOOBIE
    Do you need any othe rinfo or what i gave u enoug to sort the PCF out with?
    Cheers dude if u do this my wife would be chuffed as they r for the bedroom and lounge.
  7. stoobie
    stoobie
    Jun 3, 2006
    444
    Exeter, Devon
    +78
    Just want to check - you plug in the socket? You hold the teach-i button on the remote while pressing the on button for either 1 2 3 or 4 depending on the socket.
    Do you press the on button on the remote, or the socket? Sounds like on the remote, but do you have to press anything on the socket to make it ready for the signal?
    Stoobie
  8. JimBobUKuk
    JimBobUKuk
    Oct 23, 2005
    108
    +4
  9. stoobie
    stoobie
    Jun 3, 2006
    444
    Exeter, Devon
    +78
    Right, I think I can make a PCF up knowing that! It will take a day or two because I have to get my "old" XP PC out of mothballs as the codegen program won't work on Vista.
    As soon as it's done I'll post the PCF here. What I'll do is put in a load of various codes for you to try and who knows, one set may work, but no guarantees:rolleyes:
    Stoobie
  10. JimBobUKuk
    JimBobUKuk
    Oct 23, 2005
    108
    +4
    Dude u r the Dogs Danglies - Chers for that
  11. movie_fan
    movie_fan
    Dec 18, 2004
    503
    +18
    Oh boy, this looks interesting. My sockets work just the same, even the remote is the same. ;)
    If that works for JimBobUKuk, looks like I'll be out to get me an RG Pronto!
  12. JimBobUKuk
    JimBobUKuk
    Oct 23, 2005
    108
    +4
    Kewl then we can all bow down to Stoobie the CodeGen King :)
  13. JimBobUKuk
    JimBobUKuk
    Oct 23, 2005
    108
    +4
    STOOBIE, how u getting on then? just wondered if i could get excited or not! cheers again
  14. JimBobUKuk
    JimBobUKuk
    Oct 23, 2005
    108
    +4
    STOOBIE!
    I know i am a pain but just wondered how things were going?
  15. stoobie
    stoobie
    Jun 3, 2006
    444
    Exeter, Devon
    +78
    Sorry but a few things going on at home I hadn't planned for so haven't had a chance yet. Will get something done in the next day or two!
    I know it's a pain waiting but as I said, I can't promise it will work so be prepared to be disappointed:rolleyes:
  16. JimBobUKuk
    JimBobUKuk
    Oct 23, 2005
    108
    +4
    OK dude
    Thanks for ur help i understand, lets hope it works. >>I KNOW WHERE U LIVE!<< lol
  17. JimBobUKuk
    JimBobUKuk
    Oct 23, 2005
    108
    +4
    STOOBIE, just wondered if yo had an update on the PCF file? sorry to be a pain, just wanted to find another way if what you were trying doesnt work, i have faith in u tho :)
  18. stoobie
    stoobie
    Jun 3, 2006
    444
    Exeter, Devon
    +78
    Hi, I have attached a file with 2 sets of buttons created in different programs for you to try.
    It is a .RAR file because this forum won't allow me to upload PCF files. Once you download it change it back to a PCF and then open it in the usual way.
    I have asked my partner to try to buy me the socket set from Lidl today so if it is still in stock I should have them this evening and can experiment more easily.
    I'll let you know how I get on!
    Stoobie
  19. stoobie
    stoobie
    Jun 3, 2006
    444
    Exeter, Devon
    +78
    Damn, Lidl has sold out and if you go onto ebay etc they cost up to £20 + p&p :(
  20. JimBobUKuk
    JimBobUKuk
    Oct 23, 2005
    108
    +4
    gonna dl now and test, if my local lidl has any left, i will get you a set and u can paypal me if u like
  21. stoobie
    stoobie
    Jun 3, 2006
    444
    Exeter, Devon
    +78
    That would be really great if you can get me a pack!
    Stoobie
  22. JimBobUKuk
    JimBobUKuk
    Oct 23, 2005
    108
    +4
    STOOBIE,
    I tried and no, they dont work, am i suppose to do something else? I am testing the buttons direct for the pcf with my device via USB.
  23. stoobie
    stoobie
    Jun 3, 2006
    444
    Exeter, Devon
    +78
    no, you don't need to do anything else, other than make sure the RF is set on in the properties of the pronto.
    There will be hundreds of possible codes that may work and I can't load them into a PCF, so what I was hoping to do was get the sockets and have a go from the PC linked to the pronto.
    I trust you are trying to teach the new codes to the socket as per the instruction that came with them.
  24. stoobie
    stoobie
    Jun 3, 2006
    444
    Exeter, Devon
    +78
    Just a thought, you have to install the PCF disconnect the pronto from the PC and then use the codes. I don't think it will send the RF when used with the PC.
  25. JimBobUKuk
    JimBobUKuk
    Oct 23, 2005
    108
    +4
    right, will try that now....
  26. JimBobUKuk
    JimBobUKuk
    Oct 23, 2005
    108
    +4
    just a thought, do i need to set the device to rf? if i do, it talks about an extender, i dont have one!
  27. stoobie
    stoobie
    Jun 3, 2006
    444
    Exeter, Devon
    +78
    Yep, it needs to be set to RF, don't need the extender! (That is an IR to RF back to IR thingy if you want to hide your stuff in a cupboard)
    Sorry for the delay in replying I keep going downstairs to watch TV!
  28. JimBobUKuk
    JimBobUKuk
    Oct 23, 2005
    108
    +4
    Hi mate, set the pronto to RF-0 didnt work
    set to RF-1 2 3 still didnt work.
    The pcf is uploaded to the pronto
    Anything else you can think of?
  29. stoobie
    stoobie
    Jun 3, 2006
    444
    Exeter, Devon
    +78
    Changing the RF on the Pronto shouldn't make a difference, but as I said it may not be anything you are doing wrong, it may be that the codes I sent are not the right ones and as there are hundreds of different ones I can't guarantee any I send will work.
    I'll keep searching and see what i can find but as much as I'd like to help, you may find that it simply can't be done!
    If I'd managed to get the sockets from Lidl and had them here to see how they work and spend time I might do better, but as I said, both my local stores are sold out! It is far easier doing something if you have it physically in the same room that trying to imagine how something looks and works
  30. JimBobUKuk
    JimBobUKuk
    Oct 23, 2005
    108
    +4
    STOOBIE,
    if you promise to return, i will send you a socket, the remote and the dimmer socket too.
