Pronto RU940 Problem
Discussion in 'Home Cinema Control & Remote Controls' started by booktrunk, Sep 9, 2004.
  1. booktrunk
    booktrunk
    Feb 6, 2004
    602
    Leicestershire
    +3
    Hiya,
    I went about six months without using my pronto.
    So I finally decided to get off my arse and configure it again, so anyway did all that, stuck some new batteries into the pronto uploaded from the software and arrrrgh!!
    The display doesn't work the backlight comes on. If I move the contrast wheel the whole screen goes dark or light, BUT I just cannot see anything on the display.
    If I take the batteries out and put them back in I get the same just nothing on the display. If I guess where the buttons are correctly then I can press them and they actually function fine. So it works it's just I cannot see anything.
    Anyone got any ideas?
    Steff
  2. SimonO
    SimonO
    Nov 4, 2002
    3,193
    71
    Hertfordshire
    +64
    Try pressing the reset button on the bottom of the unit...
