Pronto Rechargables
Discussion in 'Home Cinema Control & Remote Controls' started by Plump, Jul 21, 2002.
  1. Plump
    Plump
    Feb 22, 2002
    638
    19
    under the bridge
    HI,
    is it safe to stick four 1.2V NiMh rechargeables (instead of original rechargeable pack) into the Pronto and Charge it in the Docking station.
    Plump
  2. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    errr why??
  3. Plump
    Plump
    Feb 22, 2002
    638
    19
    under the bridge
    Because I had bad luck and got one that can't be charged well. I tried another one from a good friend of mine and it works well. So simply it was bad luck.
    Now I have choice to order another battery pack or simply to buy 4 appropriate rechargeables.
    This was my full answer to your stupid question.
    Plump
  4. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    You did not say why in your first post so how does that make my question stupid????
  5. Plump
    Plump
    Feb 22, 2002
    638
    19
    under the bridge
    no offense
    I wrote that because when we ask the question here, we ask it because of question itself, and not to tell someone whole background story - needs much more typing and time is what I do not have :-(
    so please no offense
    I still need to know if anyone experienced anything bad by chargingl NiMhs inside Pronto.
  6. LDR
    LDR
    Apr 1, 2002
    2,332
    Wales
    +101
    If you check your pronto handbook, on page 4..
    Warning Use the recharging dock only with the Philips NiMH rechargeable battery pack.
    Now I know your gonna say "Yeh, but who listens to the instructions anyway", but for about £10 you can get yourself an independent battery charger & save yourself the worry...
    My 2penceworth...
    :p
  7. Plump
    Plump
    Feb 22, 2002
    638
    19
    under the bridge
    Yes of course, but I see no reason not to use them. After all I still have that docking station! And this battery pack is nothing but 4 AA size rechargeables wrapped together in a pack! I wanted to share experiences but seems no one did this. I will do it anyway. And nothing can go wrong!
    Cheeers
    Plump
    P.S LDR thanks for your effort anyway
  8. Plump
    Plump
    Feb 22, 2002
    638
    19
    under the bridge
    4x NiMh 1,2V , 1200mAh inserted and charged
    All fine
    Either lucky or it really works :)
    Cheers all
    Plump
