Peter Shilton
Has anyone had any problems with strange goings on with their Pronto?
I have downloaded some graphics from remote central and cut & pasted them into my ccf. All is programmed perfectly and looks fine, properties etc.
However when i download it onto my pronto the settings have changed!
Eg the Play TV graphic, jumps to the DVD menu etc.
If I then upload the ccf back to the computer it has the wrong" settings on. I then change the properties, save as and download it again the same thing happens!!
It is driving me crazy.
If I make my own button it works fine, but the fancy graphics look better.
It is as though there is some hidden instruction in the GIF.
These gifs change their pic whilst executing so is there some problem there?
Also
I have a Toshiba RPTV for which I understand there are no discrete codes. Therefore to play EXT 4 I have to get it to change to channel One so it knows where it is then toggle 4 times to get to ext 4. This causes problems with the delay because if the TV is off it takes longer to warm up than if I am just changing channels, so I have to set the delays and it takes about 8 seconds to do everything. This does not impress the wife. If we were watching EXT 3 she says she could pick up the TV remote, press it once and we would watch EXT 4. Why is the Pronto better??!!??
It makes it a struggle to justify. How can I get round this?
Should I have done this as 2 threads? (does this question make it 3 threads?)
Also
