Pronto Pro TSU 7000 - how to 'extract' bitmaps.....
Discussion in 'Home Cinema Control & Remote Controls' started by Lighty, Jun 7, 2005.
  1. Lighty
    Lighty
    Mar 7, 2002
    2,811
    East Yorks
    +138
    hi
    just bought a 7000 and have downloaded a couple of good setups from Remote Central....
    is it possible to take a bitmap off a panel and tweak it to suit?
    cheers
    sean
  2. Loada
    Loada
    Mar 4, 2003
    585
    Guisborough, North Yorkshire
    +48
    The .pcf file format is just a renamed zip. Rename it and open it with your favourite archive app (WinRAR, WinZip etc). You will see the config file (xml) and the bitmaps in a sub directory.
    Hope that helps...
  3. Lighty
    Lighty
    Mar 7, 2002
    2,811
    East Yorks
    +138
    superb effort that man
    there's my spare time gone then.........
