pronto pro rs232 interface
Discussion in 'Cables & Switches' started by carillion, Jan 28, 2004.
  1. carillion
    carillion
    does any body know if i can get a 232 interface for a phillips pronto pro thanks
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    Are you trying to do 232 control from a pronto or 232 control into a pronto?
  3. carillion
    carillion
    hi retro, im in maidenhead (work) but i live in h.wycombe funny eh
    i have a dome camera mounted on a ceiling that is 232 but the system its plugged into has visca camera control protocol so it wont talk to the dome.
    so i need an interface that will respond to ir commands from the pronto and send 232 strings to my dome camera:p
    at least i think thats corrct the guy who wanted me to post the question isnt here at the mo..
    Thanks DANNY
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
    We should have something that will do that job. A little box called a Marata MCU-UNI-IR. It will take in an IR command and output a 232 command or an RC5 IR command. I'm at work at the moment (snow everywhere so traffics stopped) but not sure where the documentation is for it, so I'll have a look tomorow.
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,078
    The Borders
    +2,530
    carillion
    Xantech supply two devices:
    IR232 - fixed baud rate
    IR232A - variable baud rate
    See http://www.xantech.com/
    Possibly the same or similar to Richard's options.
    Best regards
    Joe
  6. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
    My little board is a custom made jobbie Joe.
    Sadly due to being a distributor I'm not entirely sure of how much it retails for.
    It's a pretty flexible thing though, plenty of options on it.
    Pretty much an addon to the MCU range.
  7. carillion
    carillion
    thanks guys im on site in london after i pack up the van so i will check back later if poss
    thanks Danny:D
