Pronto pro help
Discussion in 'Home Cinema Control & Remote Controls' started by Geezer, Jan 21, 2003.
  1. Geezer
    Geezer
    Aug 5, 2002
    2,833
    68
    +25
    Hi all.
    Got my nice pronto pro for christmas but have got so annoyed with the thing i havent really used it. I downloaded some elses CCF? and taught it all the butons, but i cannot get the sky tv guide box office services buttons to work it learns them but they dont do anything. Ive updated the firmware but that made no difference. Ive asked at remote central no real help there either.
    Im a bit stuck when it comes to proto edit too
    Is there anywhere i can take it to get it all programmed?
  2. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Hi there...I think the Pronto's only real drawback is the software shipped with it,and the total lack of manufacturer support.....I had similar problems with mine either seeming to forget IR codes previously learnt,or not keeping codes downloaded using CCF's from elsewhere.
    I think merging the bits of the CCF you want to use with your current file may solve the problem....just be sure to save a current CCF copy before doing it!...worked on mine though and finally got the thing working with all my gear....hope this helps.
  3. Geezer
    Geezer
    Aug 5, 2002
    2,833
    68
    +25
    Still cant get it sorted :thumbsdow
  4. dnrc
    dnrc
    Dec 23, 2002
    307
    16
    Near Norwich
    I would try relearning them until they do work. Try different distances from the remote, different durations of key presses etc. You should eventually get them.
    And stick with pronto edit, when you crack it you will find it is really powerful and you will be able to make little changes whenever you want.
    Personally, i found PE fairly intuitive, but can see why a lot of people have trouble with it. I think now though, at the Philips site (i think that's pronto.philips.com ) they have a PE user guide.
