Pronto Pro cable
Discussion in 'Home Cinema Control & Remote Controls' started by bamber, Nov 21, 2003.
  1. bamber
    bamber
    Dec 2, 2002
    216
    16
    Anyone know where I could get a replacement Pronto Pro programming cable?
    I'm a total scatter brain, I have a pronto, marantz 5000 and a pronto pro and managed to lose all three cables.:eek:
  2. Jason S
    Jason S
    Don't know about buying one, but you could build one, it's easy enough and is the same as the serial cable used to hack a Tivo via the rear port (which is how I found it). It's only 3 wires and is real simple.
    Diagram here
    http://www.tivohelp.com/archive/tivohelp.swiki.net/35.html
    it even tells you at the bottom you can use your pronto cable to access the Tivo.
    I built one in about 15 mins and the bit's cost under a fiver from maplins.
  3. bamber
    bamber
    Dec 2, 2002
    216
    16
    Jason S,
    That information was very helpful. I will have a go at building one.
    Thanks very much.
    Garry
