Pronto + Pioneer DV-575A
Discussion in 'Home Cinema Control & Remote Controls' started by applevenus, Aug 20, 2005.
  1. applevenus
    applevenus
    Have a Pronto RU-890 and a Pioneer DV-575A.
    I'm looking for CCF file(s) for this player, I've searched and read remotecentral.com with no luck.
    I suspect that another model CCF will work just fine but haven't been able to figure out which one.
    Has anyone out there successfully done this or can suggest a near similar Pioneer model that I should try CCF file for ?
  2. shodan
    shodan
    Dec 11, 2001
    11,615
    shoeburyness
    +6,585
    You could try finding a layout that you like and has all the buttons you need, then just re learn each buttong from the original remote?
  3. ab1385
    ab1385
    May 30, 2004
    1,321
    Cardiff
    +74
    Is there a 565 file? Might be worth trying...
  4. applevenus
    applevenus
    the layout idea is a good one.
    there's a file for the 565A but all it does is provide region free functionality.
    I think I'll give shodan's idea a try.
