Pronto - Pause in a macro ?
Discussion in 'Home Cinema Control & Remote Controls' started by S Helton, Jan 10, 2005.
  1. S Helton
    S Helton
    Oct 29, 2004
    68
    +4
    I wonder if a Pronto owner can answer the following for me please?
    I need to program a sequence of events into a Pronto (which I think is called a macro), but need to allow a bit of pause at certain points to allow for the receiving device to respond (I'm talking of a second or so pause).
    Is this possible? If it makes any difference, it would be via RF so I don't need to worry about the Pronto being in line of sight.
  2. mattross
    mattross
    Oct 23, 2004
    265
    +7
    If U double-click on a button so that the Pronto NG software brings up the 'Button Properties' there is an 'Add Delay...' button that lets U sequence in gaps in 0.5 seconds increments anywhere in your macro sequence.
  3. Sandman
    Sandman
    Nov 28, 2002
    3,538
    Glasgow
    +1,247
    The same feature is also in the prontoedit software i.e. original pronto and the prontoNG.
  4. mambojambo
    mambojambo
    Dec 23, 2004
    142
    +3
    you can also ad a pause to a macro with a prontoneo too
  5. mjn
    mjn
    May 24, 2001
    21,859
    Herts, England
    +9,541
    It's actually 0.1 increments. :lesson:
  6. S Helton
    S Helton
    Oct 29, 2004
    68
    +4
    Thanks guys - just what I need.
  7. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    The default 0.1 second pause can be changed to any duration you like. Double click on the 0.1 sec and a box will open. Highlight the delay and type in the length you want eg 1.5 sec then press enter.
  8. mattross
    mattross
    Oct 23, 2004
    265
    +7
    Ahh...only clicked it quickly and saw a 0.5 as the default so assumed that was the minimum increment.
