Pronto Pain
Discussion in 'Home Cinema Control & Remote Controls' started by patmyhead, Dec 30, 2002.
  1. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    hi
    i HAVE THE 940 RC THAT HAS WORKED OK TILL I TRIED TO USE PRONTO EDIT
    I CAN DOWNLOAD ALLRIGHT BUT NOT JUST THE DEVICE I WANT BUT OTHER UNWANTED DEVICE SETTUPS
    I NOW HAVE LOST ALL THE FACTORY SETTINGS AS WELL AS ALL THE DEVICES THAT I HAD SPENT HOURS LOADING
    HAS THESE SETTINGS BEEN LOST FOR EVER OR CAN I GET THEM BACK OR EVEN HOW CAN I RESET TO FACTORY SETTINGS RESET BUTTON ONLY RESETTS TO WHAT I HAVE DOWN LOADED
    P@
    SONY 11HT DENON AVISR AMP PACE SKYBOX ARCAM 88 DVD
    JVC VCRS
    HUMMAX 5400SAT ECOSTAR SAT PHILLIPS REAR PRO TV
  2. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    I have now got the pronto back to its factory state
    now all i have to do is suss out how to just load one device at a time
    P@
  3. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    HI PMH
    This may seem obvious but have you tried deleting the devices in the tree menu .thats what i do to load a new device.
    Jim
  4. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    First thing I tried I must have done summet wrong
    Thanks fr reply
    P@
  5. dnrc
    dnrc
    Dec 23, 2002
    307
    16
    Near Norwich
    try uploading the factory default setup to the computer, editing it and then sending it back to the remote
  6. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    Done that but even when i deleat all devices keeping just the one i want (sky) all other facyory settings are gone all i have is the new sky setting
    P@
  7. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    Got the pronto edit bit soused just a little fine tuneing then I will try my luck at doing my own files then if they work out ok post them at remote central
    any one know of another download site as i need a file for denonavc1sr the one at central for my 940 seems to have bugs not all icons work
    Happy new year to all my readers
    P@
  8. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    Disreguard last post I give upwith pronto edit
    3 days in front of pc i have sores on my ar make that bottom
    P'
  9. AMc
    AMc
    Nov 20, 2000
    6,827
    Near Norwich
    +3,402
    Save the factory configuration file on the PC.
    Open the downloaded configuration file and choose "replace the current configuration" in ProntoEdit. Delete everything except what you want, now save to a new file name.
    Now open the factory configuration file and then load the stripped down file choosing merge.
