Pronto & NTL
Discussion in 'Home Cinema Control & Remote Controls' started by BASS, May 13, 2003.
  1. BASS
    BASS
    Does anyone know how i can get my pronto pro to work with my NTL/ Cable & Wireless box ?? Ive looked through remote central and couldnt find any relavent information.
    Has anyone done it? if so how
    cheers
  2. KW1816
    KW1816
    Jun 14, 2002
    836
    Surrey
    +14
  3. Mo-S3
    Mo-S3
    Jan 24, 2003
    92
    cheshire
    +4
    Isnt there any other way ??
  4. Loada
    Loada
    Mar 4, 2003
    592
    Guisborough, North Yorkshire
    +51
    No. The NTL cable boxes use IrDa remote control not the normal "consumer IR" signal. The RedEye devices converts consumer IR from a universal remote such as the Pronto into the IrDa signals the cable box uses.
    To my knowledge, there is no other way.
  5. shoehorn
    shoehorn
    It works perfectly... and the £25 (or so) is money well spent (IMHO) otherwise I would have an expensive paperweight...
  6. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +148
    RED EYE
    There is no other way and it's well worth it.
  7. MrAnderson69uk
    MrAnderson69uk
    May 12, 2003
    190
    +14
    BASS,
    Not sure if there is a defference between the ProntoPro and Pronto 1Mb in terms of IR capability, but if what what is being said here is true that it's IrDa and it won't work, then how come my setup is working ? ...I'm using the Phase 2 (RGB capable and not S-Video, non-RF loop-thru, no interactive card slot in the door to the viewing card) Digibox from NTL manuf'd by PACE.
    Here are the CCF files off Remote Central.
  8. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +148
    Depends on the model of the stb.
    I think the newer ones (4000 series) will work with the Pronto.
  9. Loada
    Loada
    Mar 4, 2003
    592
    +51
    Some of the newer cable boxes use consumer IR (not IrDa).
  10. MikeHarrison
    MikeHarrison
    4000 boxes can ues IRDA or RC5, although there are some issues with RC5, including no 'i' key. 4001 boxes use RC5 only. Model number is on a label underneath. If your STB has the arrow buttons under the display, it's a 1000 or 2000 and Red-Eye is the only way to control it from Pronto.
