pronto noise
Discussion in 'Home Cinema Control & Remote Controls' started by darren7, Mar 9, 2003.
  1. darren7
    darren7
    HI
    my pronto is making a high pitch whistle when the light turns on.
    I dont think it done this at first and is quite loud and annoying.
    anyone had this problem....?
  2. crazymatt
    crazymatt
    I have read somewhere that this happens when the backlight is coming to the end of it's life?
  3. Gordie
    Gordie
    Mine makes this very noise and did so since I first switched it on. I thought it was normal.
  4. darren7
    darren7
    this one is almost new, anyone else have this problem..... so I can return it.
  5. crazymatt
    crazymatt
    I've had 4 Pronto's in my time..
    and only one ever did it, the backlight went about 2 weeks after it started.
  6. andyk
    andyk
    Dec 31, 2001
    769
    46
    North Yorkshire
    +166
    All LCD panels make this noise apparently. It is someting to do with an inverter and very high voltages I believe (but I don't know any more than that so don't ask).
    I read a thing about it on remotecentral a while ago. Don't worry about it.
  7. Eakley
    Eakley
    I've had mine for 2 years - it's done it since day one. I've just had to have the screen replaced, but it was an input problem and nothing to do with the noise. After the repair the backlight still makes the same noise.
  8. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    As andyk has said,it's the inverter used to run the display....held close it can be irritating,but shouldn't be loud enough to be audible under most normal circumstances.
  9. ChrisA
    ChrisA
    Jul 14, 2002
    189
    Suffolk, UK
    I'm sure if you read the handbook it says somewhere in there that they do this. I've had mine for a year or so - it's always done it and work sperfectly.
    C
  10. darren7
    darren7
    Mine seems very noisy, across the room, didnt this it was this loud from day one
    D
  11. G1OSE
    G1OSE
    Jan 22, 2003
    292
    london
    mine does it very quietly though have to put it to your ear to hear it
    solution turn up the tunes or the movies that will make you much happier !
