Pronto Neo
Discussion in 'Home Cinema Control & Remote Controls' started by gavan, Feb 14, 2003.
  1. gavan
    gavan
    Dec 20, 2001
    3,984
    Rapture
    +286
    Anyone here using the Pronto Neo? I've been thinking of getting a Universal Remote for some time and this seems to fit the bill... I don't need the all-singing all-dancing functionality of something like the Pro but I'd like something more than a basic universal remote.
    So - any experiences and recommendations?
    Gav
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    Do you want the hard buttons that you get with the neo or will a standard Pronto be ok?
    A standard Pronto can be bought for £99 from Richer Sounds but a Neo is around £180, that is a lot of extra money for a couple of hard buttons!
    The screen on the Neo is quiet small and low resolution compared to the Pronto.
    Mark.
  3. AOD
    AOD
    Feb 7, 2001
    707
    London
    +4
    Also bear in mind that the Neo seems to have acquired a less than stellar reputation for its IR learning abilities. :(
    I would save your money and get the Pronto.
  4. russraff
    russraff
    Aug 1, 2000
    2,315
    Newcastle
    +51
    I had to take my Pronto Neo back, as it couldn't learn just about anything! The Neo wouldn't learn: Sky Digibox (grundig), Harman/Kardon amp, Panasonic VCR, Some of my (then) Sony 7700, PC Speakers, Thule CD Player. Admittedly some of these components aren't exactly popular, but my Marantz RC1200 can learn them fine, and that cost just £30!
    Oh, and yes, I tried everything to get those codes learnt. Better off with a real pronto, or RC1200.
    What are those Kameleon (spelling) remotes like?
    Russell
  5. Tides2002
    Tides2002
    Jul 5, 2002
    122
    +10
    I’ve just upgraded the firmware of my Neo (to V1.5.3). The update is supposed to improve the learning capabilities of the Neo; indeed it seems a little better but still doesn’t give you confidence that the learning process will be successful. :rolleyes:
